[Found!] Pre ‘66 slant six engine mount brackets
MidnightSwinger
Woodland CA
See picture below, I need the motor mount brackets for my 65 Dart. From my research they need to be from a pre ‘66 slant.
Correct. I might have an extra set. I will kook, today. Just a fyi, you will need a 66 or earlier oil pan and pickup tube, if using a engine from a later year. Also if the engine is 68 or newer and using an 67 or older automatic trans you will need a crankshaft adapter.
The engine is from a 67.
