StephenShaw
64Valiant200ConvV8
I see many '65 and later neutral safety switch posts but I need info pre-'65. My '64 Valiant push button select neutral safety switch has a crack next to the stud in the epoxy that leaks fluid when the torque converter drains out a week after shut down. Part number 1704100 is on the side. I have removed the switch and temporarily capped it with a 3/4-16 bolt - no leaks. It looks like the 1704 283 is similar but several posts state this part is not compatible with pre-'65 push button trannys. Has anyone used the 1704 283 switch successfully on the '64 push button tranny? These 283 parts are quite pricey and I don't want to fork out the cash for a part that won't work. Thanks in advance.
