besides pulling off the intake, is there a way to tell if a 318 is a factory roller? I know that in the late "A" series run that Mother started putting hydraulic rollers in the 318 but short of tearing one apart how can you tell?
its a carb. Guess I'll find out when the eddy intake I bought from a FABO member gets here and I peel the lid off of it. It runs good (started it in the 5th ave before pulling it out) but I still want to add a mild cam. I'll do like Daliant sez and pull the dist.88 was first year for the 318. Not sure how to tell really quick except maybe the throttle body verses a carb.
all roller LA's were painted BLACK from the factory...and here is the rest.
1985 started production of the LA Roller 318 in Dodge Diplomats, Chrysler 5th Avenues, and Plymouth Fury's....and d150 trucks in 1988.
360's remained Hydraulic Cam until 1988 when they received the Roller Cam/Lifter galley from the Roller LA 318....and electronic fuel injection. Chrysler swapped from the Roller LA 360 to the Magnum 5.2/5.9
in mid 1992.
