o1heavy
1974 dart sport
whats the deal with everyone suggesting not presoaking lifters
before for breaking in a new cam
man, it sure will be scary with all the lifter noise
and it will a little tough to get the lash right /not being able to fill the tension from the lifter
There is another way!
Pull the distrib and put your priming tool in the hole.
Then as you turn the pump, a buddy slowly turns over the motor by hand and all the lifters will fill with oil and your whole engine will be oiled up and ready to start as soon as you put the distrib back in!
Works for me!
Works for me!
Pumping the lifters up before is a good way to bend push rod's!!!!!
Oh really? How you gonna stop lifters from being pumped up when you HAVE to prime the engine's oiling system before startup? Are you advising against THAT? Do tell.
Stroker, I know where you're coming from. But try to look at it from another point of view... I know that's hard for you...lol.
You know some of you fellas with your words of wisdom should write some tech articles on this kind of stuff. Lots of great info on this site but most of it fails to make the tech articles. We need more of that stuff. Im asking yall to put your wisdom to use and write some tech articles. Stroker Scamp Tech article on engine building would be a great one for you. Or even short engine assembly segments. Photos are a +
I lube them good but I don't pump them up. They should stop rattling within 10 seconds of startup unless you've got a bad one.
