I didn't mean chrome on plastic. I was talking about the console. The plastic with a coating does fade. Anything to help with that situation. The radio bezel and gave assembly are newChromed pot metal can be waxed just like paint.
I have not seen interior chrome on plastic pit before?
I have the rechromed plastic. Thanks for the info about waxChrome doesn't rust, it is the ferrous metal underneath that does. Scratches through the chrome plating is what allows the oxidation. Just seal from oxygen, outside air ( wax, clear coat etc). It will never rust. Have the plastic "rechromed". The current plastics technology has advanced a lot in recent years.
If you wax before clear coat I wouldn't think the clear would stick. That's the reason for using wax and grease remover before paintingI'd wax before clearcoating. The stuff that pits is the pot metal, Seems to come up from within.
I meant that I would rather wax than clear coat. Ie. I would wax that chrome part as a first choice. Clear coating would be a second choice.. An understandable mistake how I wrote it.If you wax before clear coat I wouldn't think the clear would stick. That's the reason for using wax and grease remover before painting
