low compression? pour some 30 weight motor oil down the car, yes enough oil. if been sitting a long time, that will also help with the cyl walls.
I'd like to keep the slant 6. I'm got some diesel tech buddies who want to help me turbo it when I get a reman motor with forged pistons etc. I just hoped I could make the original motor run and drive even if it was s little smoky and slow so it wouldn't just be sitting til I build another slant 6. I was 5 when someone parked this old girl. So now, thanks to the info on here I'll get some rods. Clean this sucker out of the gunk in it. Try to get that head working decent again... hope I didn't get some piston slappage... and see if I can make her putter back to life. Another slant 6 was always the plan but in the mean time I thought I'd make her run again if possible and it's been a hell of a journey so far. Thanks guys. I'll keep you updated. Next weekend I'm going to get back out thereId get it running first. straighten the bent rods with a hammer over a flat surface, roll them to get them as straight as you can. Go over to slantsix.org and put out a call for some straight pushrods. DrDodge (Doug Dutra) has plenty of spares of everything. while your waiting, get your valves unstuck: pull the valvetrain and lay a straightedge over the valves and work on the low ones. once you get them all free, cycle them once or twice with only that cylinder installed to make sure they are getting full travel by hand cranking. when they are all free, reinstall with straightened or new pushrods , lash it .010 in and .020 ex and fire it up. once you get it running, put a quart of diesel into the oil filler and let idle for 5 minutes, then do an oil change. the diesel will thin the oil and help clean the sludge. Just use cheap walmart oil as its going to come out again soon. Give the old girl a chance, Youd be suprised what a few minutes of running will do to an old motor. once you get it running, you can then determine if you need a valve job or a rebuilt motor. There are plenty of used motors on craigslist or here. dropping a 360 in is more work than you think with lots of supporting parts that may nickle and dime you past interest.
Like I said, there great motors, way under appreciated, and if you know the tricks there is some power to be had from them. I'm old school, I like cubic inches, but my 68 dart GT 225 slant car is a blast to drive, and the fuel mileage between that and my 340 car are not even comparable!
Some pics of head... gas tank swap and car when I bought it
have faith - you're on the right track... these bumps just make it that much sweeter when you get 'er done!
hey, that thing looks complete.. your 3/4 the way there! Yeah, that head needs some attention. Wanna challenge? Try getting the lifters out...Er, dont bother, just get some oil on that valve train and let her clean herself out. Here is another tip: put the oil pan under the oil filter before you unscrew it..
Interestingyou can put it up on the fender but it will drain back and you dont want that. ITs fine where it is, its just a messy job. The first ones had a canister style oil filter down there where you unscrewed the top like a pickle jar and removed the cartridge filter from the "jar of oil". no mess!
The world is just going crazy lolNo Ag or FFA? How about no music or PE? This one takes the cake: NO HOMEWORK!
Florida elementary schools ban homework
And when their Hondas blow up from a 50hp shot of nitrous and all that plastic body paneling starts to turn to dust, your steel car will still be kicking.
Every project I tend to get in over my head. But then I learn new things and am better for the next project. I wish I had more knowledge faster so Id have more skills faster and could get my projects done faster, better and cooler.The world is just going crazy lol
