roccodart440
- Joined
- Apr 19, 2010
- Messages
- 6,896
- Reaction score
- 3,729
How are you using that photo effect?
I'm not out to discount others posts but.. "It looks good" ? That may be true but there a saying, "A dead man looks good" LOL
"Guarantee it handles better" ? Ask for a money back guarantee.
If you'll google the history of auto tires starting with the Ford Model A you'll learn that handling and ride quality will suffer tremendously where a auto doesn't have the modern suspension components that accompany the low profile tires.
If what your car looks like from the outside means more to you than ride quality inside... Ignore this post.
Good luck
Ride quality and performance most often don't go hand in hand.
The second problem is tire selection. I really wanted a tall tire, 28" would of been great. But as I mentioned above most of the 17"+ tires are in the 25" tall range that 285-40-18 is a great compromise of width and height. The wider tires would have been shorter in most cases or extremely expensive. The short wide tires look great from the back but a little odd from the side view on some of these older cars.
zhandful...were did you buy your wheels at? Is that a factory color on your car?
I put a lot of thought and time into tire choice and ultimately found these goodyear f1 supercar 285/40/18 for $93 each plus $60 shipping for 2. Nothing else came close in terms of price. Looks like it's gone up some.
Lower price = freedom to :burnout::burnout:
Some?! $450 each is a far cry from $93 my friend! Man what sweet rubber though
I see this guy is selling "takes offs" on e bay fro 93 each...how does the asymmetrical work, no rotating, have to buy right and left?
http://www.ebay.com/itm/2454517-245...-OFF-TIRE-95-TREAD-LEFT-ON-TIRE-/181266969653
If the tire is both directional and asymmetrical, it can only be moved front to back, not side to side. If different sizes on front and back, no rotation. I believe asymmetrical only indicates different tread on 1 half of the tire than the other half. Large tread half would be mounted to the outside. Not all asymmetrical tires are also directional.
These particular ones are not directional. So, they can be rotated side to side. Also, front to back if the same size.
The tires indicate what side is to be mounted to the outside.
That price is for FOUR
I don't intend to rotate.
This is not 100% true 2005 to 2011 charger wheels do fit
That is what I have on my Duster
f u g l y
Here is a shot of my 18's on my dart.
