dart360swinger
Boosted
I tried swapping out valve springs today in the dart. I'm going from a single valve spring setup to a twin valve spring set up. I'm also doing it while the heads are still on the motor. I'm using compressed air to hold the valves shut. My problem is the valve spring compressor I'm using. It compresses the single spring just fine, but when I put it on the new springs, it only compresses the "main" spring. The inside spring is still to stiff and hangs out the bottom, making it to difficult to get it down far enough to get the keepers on. What do I do? Do I need a different tool? I really don't want to take the heads off.
Thanks
Jake
Thanks
Jake
