RDJ
I have the FelPro 1807 oil pan gasket (LA 360). The rear seal appears too long. Is this fine, or should I use a different kind? Any suggestions? As you can see by the photo, it has a wrinkle when it is seated at the base. It seems to me that when I put the oil pan on, there will be a wrinkle somewhere in the gasket. Goop up the channel with RTV?
