Pig Pen was hiding some more secrets!
I was pretty sure she had some secrets. It is kinda funny what some people think is actually a "good" repair.“Well what we have here is a situation !”
Top layer was mud, then strips of metal and very thin tin. HahaWhat WAS that stuffed all down in the lower quarter?
Did you see how thick the filler was on the lock pillar?Hard to believe somebody thought that was "ok". Why couldn't it have been stacks of 100s?
I do have a stupid question though. Why did you cut just below the quarter seam at the sail panel instead of cutting the seam itself?
Just to access the wheel well. I am doing both the tail panels, trunk floor, and drop offs. The quarter will be last so I will remove it at the factory seam when I start to fit the quarter up.
Yes. I just cut it with my chisel bit for quick access to the wheel wells. I will remove it "correctly" laterzOk, so a short cut "for now". Cool.
I feel like every car with a little bit of rust has to be hiding all kinds of gremlins underneath. This post only feeds my anal retentiveness. It makes me want to have the entire car disassembles down to the every last spot weld. This post gives me anxiety!!!
Thank you! Lots to do yet.Very nice progress!
Thankfully my shop has a ceiling mounted furnace. 68 degrees whenever I want. Been cold here in Wisconsin lately!I know the feeling! Too cold to go out in the garage right now
