It’s a front disc / drum I have a extraBuy the right valve. Looks correct in the bag
When you are going to 4 wheel disc brakes you just need to use a 4 wheel drum brake proportioning valve. The one you have is a disc /drum. you need to use an equal drum/drum style. You have to use your. "Dipstick Son"
Thanks just thought I could gut out my proportioning valve and then it should be equal pressure. Read somewhere i can take out the bottom plunger and spring and will work fineWhen you are going to 4 wheel disc brakes you just need to use a 4 wheel drum brake proportioning valve. The one you have is a disc /drum. you need to use an equal drum/drum style. You have to use your. "Dipstick Son"
Yes I’m interested I imagine it would bolt up to my 5 lines just the same as the one I have? PayPal ok ? Thanks please adviseI have a drum/drum if you need one $20 shipped to your door.
Ok will doEdit your info off this page above I will send you a PM. with Pictures and info tomorrow. This is a public forum private info is not allowed. Steve
YOk will do
you get a chance to snap a picture or two of that valve block ?Ok will do
