The 400 needs high compression ( custom pistons) to deal with the size cam it would need, let's say a minimum of 255 degrees @.050 and a roller. Atleast 300 cfm of headflow. 600 hp in just a 400 will need to spin way up to make that power like 7000 minimum, a pretty damn high converter. That's not Brooks 600 HP stop light to stop light I don't believe he's go to driving a lightweight car eitherTold ally disagree. Let’s do some math…
600 (hp) divided by 400 (CID) = 1.5 HP per cubic inch.
A well thought out engine combination can do this. This is not exactly throw together parts from the bottom of the page. I would certainly invest the biggest chunk of change at cylinder heads!
I would approach this 400 only cube engine like a small block.
The best part being is the aftermarket big block head on s nicer than a small block head. A much higher ceiling of performance.
For a 340/360 @ 1.5 multiplication, it would equal 510/540 hp. A sizable cam it will need but not streetable? Well, that’s a driver/owner issue.
This can be done on 93 pump gas.
Build wisely!
I don't believe a pump gas compression 400 would be hitting 600 in the area of how he wants to drive, remember he wants nitrous too.
I'm going by what Andy f has tested .
Unless IQ52 has done it, I don't buy it.
