On a car that came equipped with OE drums, it is likely better to convert to the LBP, for all the reasons mentioned in the earlier replies. You are CONVERTING from Drums, as opposed to already having SBP discs.
With the drop in prices of SBP rotors, and calipers (all available through Centric), the prices for these two parts are now in line with LBP parts.
Look at the threads over the last three weeks and you will see prices for SBP disc rotors as low as $21 each (Centric manufactured). Calipers are also available from Centric for ~ $60 before discounts.
If you go LBP, you have to factor in the cost of adding LBP wheels - you will have a lot more choices in LBP compared to SBP. None the less, if you are running SBP today, you will have to budget for LBP replacement wheels.
A good rule of thumb is: If my car has SBP drums, always go to the LBP disc conversion, with one small caveat: Stick to SBP ONLY IF you can get the SBP disc spindles, and other suspension SBP disc pieces at a low price...which then allows you to stay with SBP wheels...
I would NOT worry about making your car just like a factory 340 Dart ...make it the way you are happy with, and that you can drive and enjoy...!
