Ps pressure line
1966 dart wagon
Sioux Falls, SD
I went to my local parts store today to pick up a ps line that i had ordered for my cuda. When i got to the store i inspected the item, and notied the line had one male and one female end. This does not match up with the way my ps is, on the pump the hose/line should be male, and on the steering it should be male to. the orginal line that was on there was wrong, plus it was hitting the exhaust manifold so it was burning the hose :silent: how will i be able to tell what line i need, the shop said i could have one custom made...all i though was lots of $$$$$$$$$$, should i just go back and look at every different design of line(the parts book has pics) and try and pick one that looks like it should work
Jack,
You could cut corners by getting a 1.5 " double threaded male coupling for the pump. Take your old hose with you to the shop, and get the new hose. Ensure the male end of your old hose is the same size as the new male and female end. The female end of the new hose MUST turn independently of the hose itself. Put the new threaded coupling in your pump, then the male end of your new hose on the steering, next just put together the female end on the coupling you just added to the pump. OR..try a different parts shop.
69signetv8 said:
Jack,
so like an adaptor, thats what they sugested, but the line they gave me was WAY! off, like i dont even see how it could work :silent: i'll just have to look around in their book and see if i can fine one to match what it should be
Take it off, plug the holes on the pump/steering and drop the hose on their counter. They "should" be able to match it up!
well besides the weird bends up by the steering box it works, i'll go ahead and do that, but now my car is still outside...and its raining, and i have to jack up the motor to get the line off :silent: :cwm10:
