getting ready to pull the engine out of my dart to swap k members. Anyone pull the engine with carb lift plate? sounds easy enough but kinda worried about lifting engine with only carb studs. would be 383 with eddy heads. no trans.
thanks for all the positive feed back guys. i figured it would work but had me a bit un easy thinking about it.
its brand new intake. will get grade 8 hardware and make sure to use anti seize and as much thread engagement as possible.
