I ended up around .120"
Jeff
Jeff
Guess next time I have the Dart on the lift I’ll add some more.I ended up around .120"
Jeff
I guess you can be the test mule. I know going up to .092 did nothing to change mine. let us know.So I took out valve and added to the stack of stock (assumed) washers. Total stack measured 0.120. New fluid although I noticed the pump very dirty on inside. I wanted to see the change vs spend time on removing/cleaning, knowing it will probably come out for more adjustment later. I did the mod while not removing the pump or lines except for the "in" line that the valve was behind. I would have to say that the added shims made a slight but noticeable difference. My plan is to remove pump once more and possibly (pending on reaction of the people reading this) go up as far as 0.138/0.139 as the new shims measure about 0.018/0.019. My other plan might be to just add an inline filter to see if that slows the flow and helps to "pump it down".
I could see how 0.092 does very little. Mine went from stock (about 0.035 I forget already) to 0.120 and I felt it was minimal.....but significant enough to be noticeable. Im hoping to clarify the source of the 0.125 number to make a decision about going further. Or Ill just wing it and put in another 0.038 and bump all the way to 0.158!I guess you can be the test mule. I know going up to .092 did nothing to change mine. let us know.
I guess worse case is I blow a seal or something and i lose power assist. If anyone can add info before I give it a go then yes.......test mule.There was a max shim stack size that has floated around. But I don't know if it is truly a fact.
Out of curiosity has anyone used one of these adjustable valves?
ADJUSTABLE POWER STEERING VALVE (PS-101) - HEIDTS
PS pumps are vain pumps, they pump more only when the pump is turned faster. I believe this bypasses some of the pressure to the rerun line.Interesting. Is it actually a regulator, or does it just bleed pressure of the high side to the return? Either way seems like it would just make the pump work harder.
