joshua dewitt
hey guys, any one ran the old mopar performance p4452782 factory muscle car reporduction camshaft and lifter pkg. 268-276-44degrees. vavle lift .429"/.444" on a center line of 114degrees. says idle to 5000rpm... it's new in the box....
i have a 318 going to run a .30 over with zero deck pistions. run the factory 318 head until i get better one.. possible 302's? have headers dual plane air gap intake , and an A998 lock up off a toggle forr hwy only. and plan to eventually run 3.23-3.55 gears... is this going to run good for the street? with p/s , p/b and a/c... and what kind of an idle would it have? thoughts.... never delt with the factory purple 340 cam before.... any links to a sound bit on the idle quallity? with headers and full perf. pipes with some sort of coffee can mufflers should sound intimadating at a light? or should i look into a voodoo cam. used them in chevys before...
