[Found!] push button slant six 904 cables and inside mechanism or whole trans
I have a shift cable for the push button control. I also have a park cable connector that goes inside the cover on the extension housing....and the cover too if you need that.
i do
i need both of the cables also looking for the detent roller mech. that the park cable connects to, if you might have that. would be interested in the cables anyways, I assume they are in working order? Thanks, Don.
Here's a photo of what I have. The overall length is about 42". The housing length is about 39". IIRC it came out of a '63-4 A-body with a 6 cyl.
