superslant
Active Member
:headbang:Hey there everybody. I have a 63 dart gt slant six with the (jukebox) push button trans still in it. I am having trouble with all the tranny fluid running out right where the cable goes in. I am unfamiliar with how this assembly comes off.
There was a retainer bolt on the outside. I removed that and pulled a little bit on the cable and there was a cylinder with grooves in it that goes into the trans housing. I know I need to remove the pan and then maybe it will be obvious how this all comes apart but just to prepare myself I decided to post this thread. I believe I am missing the o ring or gasket that goes where I am leaking because it looks to me metal on metal. Thanks for any info on this problem. Tips n tricks. Anything.
