rm69dart
hey everbody i have adj. mopar rockers that are going on a 340 j heads. what type of push rods should i be using. i am going mild on my engine build. thanks for your help.
oops my bad, yes those are the wrong ones, I have the correct ones on mine they have a cup on one end (rocker arm end) and ball (tappet end) on the other thats what you need too. Can'r find the correct Crane pushrods, here are the Comp cam ones that should work fine.this type wont work because i think i need the cone type. i have mopar factory adj. rockers.
