Shamrock--WV2NC
Will 3m hold on the swinger emblems?
That’s the ones for fenders. Is that the right size? When I got mine at a swap meet they had 2 sizes, so I got several of each. One of them worked...35 pcs script name plate emblem nuts tubular barrel 1/8" stud 5/32" hole Mopar eBay @ $8.25
If you have emblems with broken studs you can use 2 sided tape to attach. You'd have to trim theOk. Thanks for the help. I have a couple more emblems to run down or luckily find. (Lost moving to new house)
MoparMike, I too am restoring a 70 Swinger with Dodge on the trunk and hood, Dart Swinger on each quarter panel, and a pentastar on the passenger fender. I tried to PM you but your inbox is full. Do you have enough spare speednuts of the proper size to sell to me as well?I wouldnt use it. I dont like the factory plastic sleeves either. I bought a box of the stamped nuts to screw on the posts. Work great and no worry about the emblem coming loose. I got the nuts from mcmaster carr but had to order a box of 100.
Shoot me a PM.
