33IMP
That Is where either calculation or experimentation comes in. Notice it looks like it has an adjustable length? That is so it can be tailored to a certain sound frequency, aka drone.@LJ67barracuda340 have you found a different RPM where the resonant frequency moved to? Or did the J pipe move it to an RPM range where you never see?
Length can be calculated from info on line if you Google helmholtz resonator, or you can use one that is adjustable.
And yes, the end has to be welded shut, to reflect the sound wave back into the exhaust pipe.
