been running around ideas of lighteneng my duster and wondering the weight difference between the factory one and the qa1 one , and how they fit in thanks
A hell of a lot lighter than the factory k frame!
The QA1 k-frame won't save you an appreciable amount of weight, if any. They found that any more weight reduction would reintroduce flex into the k-frame, so they kept it as strong as it needed to be. According to them. The control arms and strut bars might save you a few pounds, versus reinforcing the stock.
I think that if weight savings is your goal there are far better ways that cost allot less.
power to manual steering is a huge weight savings.
fiberglass hood.
fiberglass front bumper with aluminum brackets.
light weight wheel and tire package up front.
disc brake swap with wilwoods or other aftermarket company.
now all that is done and still want to remove weight, then what? i started off with manual steering, wilwood brakes, light wheels, but still no room anywhere in the engine compartment for nothing but expensive headers i couldnt use in my turbo build. yet i still end up running logs due to frame rails so close to pass side of the engine and i dont want huge costly custom headers either. im out to make a point as well with the logs, but every ounce counts. titanium bolts etc... all one can do to remove heft of a mopar.
best post of the month.............100% spot on!!an a-body k member weighs about 30# depending which year or engine mounts are on it.
It is a difficult part to produce lighter and remain as strong. When you really look at it is a very weight efficient designed part.
Problem can be it may be not be configured how you like it.
It has a small amount of room to be lightened but not alot. Elephant ears for example when the
engine mounts are cut off may save a couple pounds.
Most k-frames are replaced as a way to change out the steering and torsion bars to a more modern design or for easier header fitment.
It is a very costly swap when compared to even the best fitting or expensive headers normally used with the stock frame. Cheaper to buy the headers.
Some like the rack steering that is normally incorporated with a tubular "k".
Some don't find any flaws with the stock manual steering box which is also very light and
difficult to improve on from a weight perspective.
You can choose about any method to get your car lighter known and it will be cheaper per pound lost than a k-frame or suspension swap.
Better spent dollars on a lighter front brakes, fiberglass body parts and aluminum engine parts than a tube frame for my lightweight needs.
I sure some will disagree with me on this. I'm ok with that. It is your money after all.
If you are serious about getting a car light you wouldn't even be considering a k-member at all but a full tube chassis. Thats when it gets real. Not the pretend bolt on stuff for street cars.
An A-body k member weighs about 30# depending which year or engine mounts are on it.
It is a difficult part to produce lighter and remain as strong. When you really look at It is a very weight efficient designed part.
Some like the rack steering that is normally incorporated with a tubular "K".
I sure some will disagree with me on this. I'm OK with that. It is your money after all.
