QA1 Lower Control Arm Bump Stops
Heywodja
The Heartbeat Stops Here
Texas
What is everyone using as replacements? Mine have disappeared while in the shop so I need some replacements.
On the QA1 items the rubber portion comes off of the stud, summit doesn’t have those in stock so I was wondering if anyone else had any suggestions
Do you have a picture? On the later set that I have the stud is just molded into the poly bump stop. The one on the left is the one that came off the LCA, the one on the right is Energy Suspension 9.9121G. Energy Suspension 9.9121G Energy Suspension Bump Stops | Summit Racing
You can kinda see in this picture it's even the same number cast into the poly
Thanks, those look like them, and I can get red ones for an extra tenth too!
Thanks 72
