[SOLD] Quality rebuilt Mopar distributors
halifaxhops
It's going to get stupid around here!
Hoppyworld, PA
Once again rebuilt Mopar distributors, all clearances checked, disassembled, cleaned, brought back to factory specifications then re lubed and assembled NOS or NORS points and condensers installed so no premature fails with the junk new components that have a very high fail rate. Then ran on one of my six distributor testers by needed RPM. Can curve also if needed using all oem parts no welding and grinding. Have a few hundred cores to choose from so I only list the completed units don't see what you need just ask.
SLANT
63
170/225 2098671 17/3
66
170 2444255
LA
64
273 2444448 13/4 MAN/AUTO A
65
273 2444791 21/5
318 2444291 48/4
273 2444853 IBS 4013 A body only 37/4
67
273 w/petronix 2642242- IBS 4013a 7/7
273 2642242 IBS 4013A 7/7
273 2642238 7/7 A/B
318 2642218 16/7 A/B/C
318 2642718 at 18/7 B/C
69
318 2875796 46/8 A/B/C
318 2875796 A/B/C
70
340 3438325 A/E body 2/0
340 3438317 IBS 4018 mt A/E
71
318 3438225 42/0
340 348522 IBS 4018C 38/0
318 3438225 49/0
72
340 3656278 22/2 A/B/E
318 3656587 17/2 A/B/C/E
73
360 3656780 40/2 EARLY C
360 3755365 18/3 C
75
318 3874090 38/4
B
Accel 30302
64
361 2444241 43/3
65
361/383 (2) 2444676 8/5
67
383 2642728 32/7 B/C
68
383 2875354 3/8
71
383 3438534 21/0 B/C/E
383 3438534 25/0 B/C/E
72
400 365696 15/2 B/C
400 3656593 49/1 LATE B/C
76
400 3755157 47/5
RB
MP aluminum case tach drive 4120942 54/5
36590432 49/5, 24/3, 40/9
62
361/383 2095836 2/2 C
63
413 209834 IBS 4011a tACH DRIVE
64
2444361 413 (300) IBS 4011C 300
65
413 2444867 48/4 C
413 2444869 C
66
440 MT 2642252 35/5
440 MT 2642251 2/6 C body
440 2642252 48/5, 28/5 c/d
67
68
440 2875362 350HP 46/7, 52/7 C
69
69 440 (350 HP) 2875754 33/8 C body
70
440 3438219 350hp 6/9, 37/9 C
71
72
440 3656341 12/2 B
Early pre 1960
IAT 4101
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IGS 4201-1 needs a vac advance
IBJ 4302A 56 Desoto
IBJ 4301A 56 Dodge
IGS 4111-1 41 dodge D20
IGS 4101
updated list
SLANT
63
66
170 2444255
LA
64
65
273 2444791 21/5
318 2444291 48/4
67
273 2642238 7/7 A/B
69
318 2875796 A/B/C
70
71
318 3438225 42/0
318 3438225 49/0
72
73
360 3755365 18/3 C
75
318 3874090 38/4
B
Accel 30302
64
361 2444241 43/3
65
67
68
383 2875354 3/8
71
72
400 365696 15/2 B/C
76
400 3755157 47/5
RB
62
63
64
65
413 2444867 48/4 C
413 2444869 C
66
440 MT 2642252 35/5
67
68
69
70
71
72
440 3656341 12/2 B
Early pre 1960
IAT 4101
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IBJ 4302A 56 Desoto
IBJ 4301A 56 Dodge
SLANT
63
66
170 2444255
LA
64
65
273 2444791 21/5
318 2444291 48/4
67
273 w/petronix 2642242 no tag
273 2642238 7/7 A/B
69
318 2875796 A/B/C
70
71
318 3438225 42/0
318 3438225 49/0
72
73
360 3755365 18/3 C
75
318 3874090 38/4
B
Accel 30302
64
361 2444241 43/3
65
67
68
383 2875354 3/8
71
72
400 365696 15/2 B/C
76
400 3755157 47/5
RB
MP Electronic 36590432 49/5, 24/3
62
63
64
413 2444361 (300) IBS 4011C
65
413 2444867 48/4 C
413 2444869 C
66
440 MT 2642252 35/5
67
68
69
70
71
72
440 3656341 12/2 B
Early pre 1960
IAT 4101
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IBJ 4302A 56 Desoto
IBJ 4301A 56 Dodge
also have allot of NOS/nors caps, rotors points and condensers. 10 and up
SLANT
63
66
170 2444255
LA
64
65
273 2444791 21/5
318 2444291 48/4
318 2444259 29/4 AT B/C
67
273 2642238 7/7 A/B
68
340-4 2875105
IBS4015A AT A ONLY
69
340-4 2875782
IBS 4015C 4/b MT a only
318 2875796 A/B/C
70
340-4 3438325 42/9 AT A-E ONLY
71
318 3438225 42/0
318 3438225 49/0
72
73
360 3755365 18/3 C
75
318 3874090 38/4
B
Accel 30302
64
361 2444241 43/3
65
361/383 (2) 2444676 8/5, 6/5 AT=MT
67
68
383 2875354 3/8
71
72
400 365696 15/2 B/C
400-4 3656329 22/1 B ONLY
76
400 3755157 47/5
RB
62
63
64
413 2444361 (300) IBS 4011C tach drive C only
65
413 2444867 48/4 C
413 2444869 C
66
440 MT 2642252 35/5
67
68
69
70
71
72
440 3656341 12/2 B
Early pre 1960
IAT 4101
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IBJ 4302A 56 Desoto
IBJ 4301A 56 Dodge
Updated
SLANT
63
66
170 2444255
73
225-1 3755042 51/2
LA
64
65
273 2444791 21/5
318 2444291 48/4
67
273 2642238 7/7 A/B
68
340-4 2875105
IBS4015A AT A ONLY
69
318-2 2875747 29/8 AT B/C
340-4 2875782
318 2875796 A/B/C
70
340-4 275HP 3438319 9/B IBS 4015C MT A/E
318-2 3438225 7/9 AT B/C/E
71
318 3438225 42/0
318 3438225 49/0
72
340-4 3656278 22/2 MT-AT A/B/E PENDING
318-2 36567275 15/2 MT-AT A/B/E W AIR PUMP
73
340-4 240 HP 3656771 41/2 MT-AT A/B/E
360 3755365 18/3 C
75
318 3874090 38/4
B
Accel 30302
64
361 2444241 43/3
65
67
68
383 2875354 3/8
71
72
400 3656593 11/2 AT-MT B/C
400 365696 15/2 B/C
400 3656593 49/1 B/C
76
400 3755157 47/5
RB
MP 3690432 37/0
MP ALUM TACH DRIVE 412092 48-4
62
63
64
65
413 2444867 48/4 C
413 2444869 C
66
440-4 MT/AT 2642252 4/6 C/D
440 MT 2642252 35/5
67
68
440 2875209 375HP 3/7 AT B/C ONLY
69
70
71
72
440 3656341 12/2 B
73
440-4 220HP 3755157 26/3 AT B/C
Early pre 1960
IAT 4101
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IBJ 4302A 56 Desoto
IBJ 4301A 56 Dodge
How bout a point type for a slant? I don't give a turd what number it is. I can curve it myself and add the FBO limiter plate. I just need a good reman.
I'm looking for a rebuilt distributor for the 273 in my '67. The only modifications are an aluminum intake and 4bbl carb. Car has an automatic and has been converted to electronic ignition. The date code isn't important. Which of your pieces do you recommend?
If you don't get a quick reply, Hoppy is off net until tomorrow. He'll get back to you.
The same as a commando curve should work fine.
