1967DartGT
Well, Im putting together a 351 ci stroker from parts on hand and I would like to get opinions on whether to build this for a closed chamber quench head or an open chamber non-quench head?
318 block bored 0.040 over = 3.95 bore, with 3.58 crank = 351 ci
Silv-o-lite 1278 flat-top pistons with 1.658 compression height.
Assuming a 9.6 deck height, this would put the pistons 0.029 down the hole.
So here are my options:
Leave the block unshaved, 4.06 0.040 gaskets, and 71 cc open chamber heads = 9.43:1 compression.
Shave block 0.029 for zero deck, 4.06 0.040 gaskets, and 62 cc closed chamber 302 heads = 11.2:1 compression. Compression is a bit high here but I dont know how Id bring it down and keep a proper quench distance.
Thoughts?
Thoughts?
