Question - 1971 Dart Swinger Rear Windows
SWING R
Howdy Mopar Dudes,
I noticed with the 1970 Swingers the rear windows roll all the way down where as on the 1971 Swingers they don't roll all the way down. They stop short a couple of inches, at least on mine they do. Was this a saftey feature introduced on the 1971's and if so is there any way to adjust them so they will roll all the way down?
Thanks,
James
And so does my 73 swinger rear windows.Also the parts car i got most of parts from was a 71,its quarter windows rolled all the way down too.Must be something out of adjustment on your car
There are adjustable stops in there. Most are L shaped metal with one bolt in a slotted hole.
Hi there,
I finally got around to taking the back seat out and the panels off to find the adjustment so I can roll the quarter windows down all the way. Trouble is I'm not sure where the adjustable stop is located. If I send you some pics I took with the panel removed could you comment on where you think it is?
Thanks,
Jamie
