buck351
I want to change the pumpkin in my 8-3/4 limited slip rearend. I've never pull one. I assume all I have to do is, drain the rearend, pull the two axels, take the cirlcle of nuts/bolts off around the pumpkin and pull it out. Reverse order to reassemble. Right?
It doesn't seem real complicated and it would save me some money installing it myself. I'm planning on having someone go thru the one I'm putting back in before I install it.
