Dart swinger 73
When I drove the car into the shop, I had brakes. After rebuilding the front end pads included. Moving to the rear. Drums were good it appeared the shoes, springs and cylinders were new too. Might have been changed and sat for awhile because of the critters set up housekeeping. Removed the master and buster to clean and paint. Now, everything is cleaned and painted. Primed the master Started up the engine and ran it for 15 minutes. Installed new rubber brake lines. CAN'T GET A DAM PEDAL!!!! Used a vacuum pump. Pump worked fine on my truck. So doing this job by myself, I went and bought 4 speed bleeders. Still on pedal. Any TIPS?????:coffee2:
