grassy
I am dry fitting a router to the stub axle just to try to understand what holds the caliber on. I will wait until the suspension is installed to really do this because of the extra weight of the brake stuff. I am not putting any of the bearings in which may be the problem.
When I install the keyed washer and nut there is a lot of play in the router.
When I really do install the router with the bearings, do I pack as much grease in them ?
I am still trying to figure out what holds the caliper on the unit.
I have torqued ever nut on the suspension so getting closer to the install.
Any help is accepted.
Ian.
Ian.
