ramcharger
Dismember
Yesterday was slow at work so I spent the day moving stuff and digging a little deeper into the garage electrical. It's not good, lol. Without getting into detail, I will say say that it's not to code. Anyway, got a few questions:
1. What would an electrician charge to replace a 100A sub panel with a 200A panel? Right now it's got a 100A subpanel on the outside with a seperate 60A feed for the AC (which is too big as the AC is rated @ 30A/230V) and a feed to the interior 100A breaker panel.
2. I'd like to run 100A service to the garage. 50A service would certainly do for my present needs, but I only want to do this once and have plenty of room for expansion. I was thinking 2 awg triplex due to the new NEC codes which would give me a 2 hots, an insulated nuetral and a uninsulated ground. The problem is, I can only find triplex 6 awg. I take it I'll have run individual cable like SE? Is there SE cable rated for direct burial? I know that even if I run PVC conduit it still has to be rated for direct burial.
I do know that I still have to add two ground rods at least 8' apart at the garage even with two hots, a nuetral and a ground from the sub panel at the house. BTW, I could do the subpanel at the house myself but I'd have to call the power company to shut the power off at the meter... Honestly, I'd rather leave that part to the professionals.
Thanks in advance!
Thanks in advance!
