Question on front windshield trim
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
Is the long bottom windshield trim piece the same on a 69 Barracuda as it is on a 68-72 Dart? Just the long bottom piece. Thanks in advance.
Actually just one minor clarification the 4-door variety uses longer side pieces but the bottom and top will work even from a 4-door.
Thanks, yes I was aware that the sedan trim is 1 9/16" longer on the two side pieces. I've cut them before and used them on as hardtop. I just was to sure about the A-body Barracuda being the same.
Wrong. The top pieces on a Sedan are a combined 3/4 inch shorter than those for a hardtop
Where they are supposed to overlap in the center, they barely touch.
