Question on instrument panel wiring (72 Dart Swinger)
Travis72dart
Wheatland, CA
I was wondering if anyone had a wiring diagram for this plug. If you can please post or pm thanks!
This is the 72 style
I don't have a diagram but I did install the same circuit board, and some new gauges in my 73 Scamp...It was real easy... Good Luck!!
You can download a 72 shop manual for free right here:
[ame="http://www.abodyjoe.com/pictures/Misc.%20car%20info/1972%20Plymouth%20Chassis%20Serv%20Man.pdf"]http://www.abodyjoe.com/pictures/Misc.%20car%20info/1972%20Plymouth%20Chassis%20Serv%20Man.pdf[/ame]
Somewhat simplified, possibly not complete wiring diagrams:
http://www.mymopar.com/downloads/1972/72DartA.JPG
http://www.mymopar.com/downloads/1972/72DartB.JPG
You can easily trace where they go right from the PC board on your cluster
For example, look through the lamp socket on the far left as viewed from the back. Is that the brake warning lamp? Notice that one trace connects both of the sockets together and goes over to the pin right next to the "key" in the locator pin. This is 12V power
Notice the other socket pad trace comes off the bottom of the far-end socket, and goes to the 2rd pin from the "key." Now go to the diagram, and this is no 10, black. Follow this down the page of diagram "B" and off the page, a couple of wires below the "big thick" RED ammeter line
Now pick that same wire up on diagram "A." Follow this over and see that it goes to bukhead connector terminal "M" where it goes out into the engine bay. This ends up at the brake warning switch
I'm doing gauges in my 74 swinger need to know what each of those wires are if anyone can help
The latest service manual you can download free is 73, either here at FABO or over at MyMopar
http://www.forabodiesonly.com/mopar/showthread.php?p=1970088617
http://www.mymopar.com/index.php?pid=31
Since there is no free '74 download you really need to get busy and buy a reprint, either in paper or "on CD." However, the 73 will be accurate for some things
Here is an excerpt out of the 74 manual (I have one in paper) standby...........
Here's the wire pinout for 74. It is slightly different than 73, but start with the 73 manual. You will find that the wiring diagram layout is much much different than for the earlier models
The counterpart of the diagram below in the free 73 manual is on page 8-168 NOTICE that in that box it says "CI-14. THIS IS IMPORTANT. That is the connector number
If you go back to page 8-152 in the 73 manual, you'll see the index. "Pick something" such as "ammeter" which is in the cluster. Notice that says C3. Notice below it is fuel gauge says D7, and temperature, D7. These are "map coordinates" on the diagrams on following pages
EG go page after page until you find coordinates D7 That is on page 8-155 Find the oil and fuel gauges. Find the reference to "CI-14" which is directly below the TEMP gauge. Notice it says "G2-20V" THAT IS wire no G2-20V shown for the circular connector. It means "circuit number" G2, and it' s a number 20 wire, VIOLET in color
IF YOU LOOK on your PC board and compare the pin layout to the diagram of that circular connector, you will be able to follow the PC board trace of that pin to only one place.......directly over to one terminal of the TEMP gauge
Also below is part of page 8-155
Awesome thanks brother that gives a hell of a starting point
