RPMagoo
Just An Old Motorhead
Are there 2 different seals, for axles, on a 8-3/4" rear ? -- One larger in outside diameter than the other. -- I realize that there would be different housings. -- If so, does anyone have the 2 part numbers ?
And the inner seal is driven into the housing and keeps the rear end lube from leaking out. The axle bearings are packed with wheel bearing grease and not lubed with the differential lube. (80/90w)Yes. There is a outer seal that you can only replace when the axle bearings are replaced.
-- I'm asking about the inner seal(s). -- I have Moser axles, and green bearings. The Housing ends may have been changed, because the normal inner seals were too small in diameter.And the inner seal is driven into the housing and keeps the rear end lube from leaking out. The axle bearings are packed with wheel bearing grease and not lubed with the differential lube. (80/90w) --
-- A 33 Plymouth coupe, with a 8-3/4", Mopar, rear of unknown year etc. I believe that the housing was cut, and possibly the housing ends were changed. It was built several years ago, and I bought it this way.What exactly are you working with ? More info = better answers --
