questions about pulleys and fan
Cameron1038
Rio Oso, CA
Hello,
I was hopin you guys can verify that ive got the right parts before i clean them up and go together with them.
These are hipefully the right:
Crank pulley, pic 1
Balancer and crank pulley pic 2
Fan pic 3
Water pump/fan pulley pic 4
Thanks
Cameron
Looks like you have identified the parts alright. Did they all come off the same engine? If so, they should work. If it is a mixed set acquired here and there, you might want to install them first to see if they line up correctly.
C
they did all come off of this motor, but im not sure if it had a/c or smog pump. ..it was a 67 so i dont think it had a smog pump.
To me that crankshaft pulley looks like a later peice for an aluminum water pump, p/s and no ac car. I can't tell on the water pump pulley. Did this 67 motor have the stock iron water pump or a aluminum one?
Oh wait, now I see that is a 3 groove crankshaft pully, I thought it was two with a separation. So that does look right for an AC and p/s iron water pump car.
You will be fine using them.
C
