70DartMike
Too many projects
Ok guys, I've never been the greatest at timing an engine. I can figure out the basics but I always seem to just kind of get it. Ok so here's what I have so far, tell me if its correct or if I have the steps in the wrong order. I know its just a simple thing but it still gets me because I haven't done it enough.
Pull the distributor and turn the crank until the line matches up at about 6 degrees BTDC, put the distributor back in and line the thing up with plug number 1, start the car and youre there. But its the part about the vaccuum that I get mixed up in. You pull the line off the distributor and the carb, and plug the carb. What idle do I set the car to? Do I do this after I've done the stuff with the crank? Thanks for any help, and any suggestions.
