no1newb
ok, i installed wilwood 4 piston disk brakes, and a new master cylinder from a darango or something that would fit my brake booster and came with front disk brakes, after i bled the brakes all around, it now the pedal goes down pretty much to the ground before it does anything, i can stop the car but it takes a second longer, i don't have any proportioning valves, would that effect it? or did i get a different master cylinder that may need to be bored out? i dont know what to do from here.
