Tiki bar jim
Anyone in A Body land have any opinions on the Quick Jack lifts?
TIA
TIA
Photo or a link please.Anyone in A Body land have any opinions on the Quick Jack lifts?
TIA
Is that the one you put a floor jack under?I have a Kwik-lift, pretty sure it is different than what you are talking about...
Doesn't look like it actually leaves you much room to work under the vehicle, either.Just my opinion, but that looks cheaply built.
7000TLX
7000TLX is a 7,000-lb. capacity, extended-length truck lift that's specially made for raising heavy-duty powerhouses. Its 66" lift point reach is ideal for long-wheelbase vehicles, trucks and SUVs. It even fits under most sports cars and sedans. 7,000 Capacity (lbs) 24.5" Lifting Height...quickjack.com
YesIs that the one you put a floor jack under?
I looked at those just now. They've halted production because of steel prices. But, they are only rated for 5K pounds. That wouldn't get my truck. Dangit.
I like this design. If it had a higher capacity, I might have to save up and get one. It would be great for alignments.I have a Kwik-lift, pretty sure it is different than what you are talking about...
My local Craigslist has a couple for about $1500. I’ve been eyeing them for a while but haven’t worked up the courage (dough). I figure I’d rather spend the imaginary money on car parts.I like this design. If it had a higher capacity, I might have to save up and get one. It would be great for alignments.
Quick? Ummm.........nope.Doesn't look like it actually leaves you much room to work under the vehicle, either.
I wonder if you could use some 4 x 4 blocks?Quick? Ummm.........nope.
It's secure when setup right.
Actually, it's a bit tight but I can still use a creeper under mine.
You can turn these sideways if needed.
For grins I tried to lift my Ram with it. I wasn't tall enough to get the rears off the drive........
