I wonder if you could use some 4 x 4 blocks?
Did you just modify your trusses? That is the problem with mine. Height.I was considering buying a 2 post mid lift set up but, it was more expensive than a floor plate, full 2 post lift.
I modified my garage to allow a full lift. A car can be raised fully, an suv of pickup not so much.
Yep,Did you just modify your trusses? That is the problem with mine. Height.
