71DodgeDemon340
Hey guys so I finally bit the bullet again and bought another retro sound radio, this one is a newer model than the previous one that went out on me. got everything installed, new radio used same connectior as the old one so it was just plug and play, everything works fine except if the radio is on and you put the trans in reverse the reversed light comes on and the radio turns off but then will come back on after about 5 seconds, if i turn the ignition on while the car is in reverse i can turn the radio on while the reverse light indicator is illuminated and stays on, i pull it out of reverse, the light goes out and radio stays on, put it back in reverse and the light comes on and the radio turns off and then 5 seconds later comes back on. The power source for the radio is from a fuse block i mounted behind the left side kick panel so i know its not a power issue. But this is what im thinking, the ground for the radio is on the bottom lip of the dash near the ash tray. The reverse indicator grounds through the body to illuminate the light, is it possible that the reverse light indicator is interrupting the ground to the radio? Just for reference the reverse indicator light and the radio ground are probably only 8-10 inches away from each other. Any thoughts or comments?
I havent tried taking the reverse light indicator loose from the dash yet, i may try it tomorrow night just for my amusement. That or disconnect the ground for the radio and use a jumper wire to another ground location and see if it still does it.
