I had read somewhere they were making a run of them.
:dontknow::dontknow::dontknow:What does it bolt to?
I want to say just the 833, if I remember right these were made so the slant guys could have an SFI approved bell, but im not positive.
that QT bell is SFI rated
and
the input shaft hole accepts the OD retainer size and the two adapters match to the two smaller input bearing retainer diameters,,
all good so far,,
only problem is,, that bell only accepts the standard size slant six flywheels, anyone find any performance slant six clutch sets lately?
QT would have had a winner if the bell had been sized to accept a 130 tooth mopar SB flywheel,, that would have opened the door for many reasonably priced clutch pack options..
I agree with ya my68 except 1 item. The slant crank bolt pattern is different than the small block so flywheels don't interchange.Wish they did.
actually all you need to do is plug one of the mounting holes on the v8 flywheel and re drill it to match the slant six crank..
"i think it was mcloud or hays that makes a billet wheel, would be a good base! dont know if the diameter is big enough though."
Mcloud has a billet slant six flywheel,, stock diameter and pricy.
