Quiet muffler choices
What I have narrowed it down to for the mufflers is a pair of Summit sum-630805 or the Dynomax 24215, Dynomax 43661 Exhaust Intermediate Pipes, Dynomax Super Turbo mufflers 17662. The plan is to tie the glasspacks to the x-pipe then use the intermediate pipe connected to the Turbo muffler then tail pipe. The the intermediate pipe has a 2" offset. The Dynomax 17662 have a 16" body and double offset inlet and outlet that will work with the tailpipes. I just have to wait till I have the Flowmaster tail pipes hung on the car to make and check measurements before ordering more parts. Hopefully it will all work and be quiet with no drone.
After alot of years with headers,2.5 Torque tech etc. I finally just spent the money on manifolds and accurate exhaust with tips. Stock size whatever that is. they sound good,but man Ill never make that money back again...:)
This might be helpful to you. I can't remember who did the coomparison.
(From a couple of years back...)
The results in HP order:
1.Flowtech Warlock (open) 374.2 hp/ 333.1 tq
2.Bassani Real Street 373.7 hp/ 333.8 tq
3.Hooker Maxflow 373.5 hp/ 333 tq
4.Borla XS 373.3 hp/ 332.6 tq
5.Magnaflow 372.8 / 332.5 tq
6.MAC 372.3 hp / 331.5 tq
7.Flowtech Afterburner 372.3 hp/ 330.1 tq
8.Hooker Aerochamber 372.1 hp/ 330.4 tq
9.Bassani 372 hp/ 333.5 tq
10.Spintech 371.6 hp/ 332.2 tq
11.Edelbrock Performer RPM 370.9 hp / 331.3 tq
12.Borla XR1 370 hp/ 334 tq
13.Flowtech Terminator 369.5 hp / 331.3 tq
14.Dynomax Ultra Flo 369.4 / 333.2 tq
15.Flowmaster 369.4 hp / 331.8 tq
16.Flowtech Warlock 366.3 hp / 325.3 tq
17.No muffs 365.2 hp / 330.1 tq
Sound Off in Quietest to Loudest (Decibels):
1.Borla XS, 80db at idle, 90db at 2,000 rpm, 110db at WOT.
2.Hooker Maxflow, 80db at idle, 90db at 2,000 rpm, 120db at WOT.
3.Magnaflow, 82db at idle, 91 at 2,000 rpm, 114db at WOT.
4.Flowmaster, 82db at idle, 93 at 2,000 rpm, 115db at WOT.
5.Flowtech Warlock, 83db at idle, 92 at 2,000 rpm, 112db at WOT.
6.Dynomax UltraFlo, 83db at idle, 94 at 2,000 rpm, 113db at WOT.
7.Borla XR1, 83db at idle, 96db at 2,000 rpm, 118db at WOT.
8.Bassani Street, 83db at idle, 96db at 2,000 rpm, 120db at WOT.
9.Edelbrock RPM, 84db at idle, 93db at 2,000 rpm, 118db at WOT.
10.Bassani Real Street, 84db at idle, 96db at 2,000 rpm, MAX. (120+db).
11.Flowtech Afterburner, 86db at idle, 94db at 2,000 rpm, 115db at WOT.
12.Flowtech Terminator, 86db at idle, 94db at 2,000 rpm, 119db at WOT.
13.Hooker Aerochamber, 87db at idle, 94db at 2,000 rpm, 114db at WOT.
14.SpinTech, 87db at idle, 97db at 2,000 rpm, 116db at WOT.
15.MAC, 87db at idle, 98db at 2,000 rpm, 119db at WOT.
16.No Muffler, 91db at idle, 103db at 2,000 rpm, MAX. (120+db).
This link below is also very informative. It is what got me interested in the Dynomax Super Turbos. I believe it was written by VOETOM.
Exhaust
I'm running Magnaflows now,but had Super Turbos on my 440 powered '56 2-dr post Savoy. Really love those mufflers!
use some kind of dynamat-like insulation and lose the drone....
Exhaust
Yes VOETOM is Tom Hand, THE go-to guy for muffler info. The extra three inches of body of the dynomax you picked, put the glasspacks as resonators should be very quiet with no drone.
Dynomax Ultraflo. Why do you want to cheat others out of hearing the best sounding mufflers on a Mopar??
Just wear these for the benefit of those that like it loud!
Best sounding? Under full throttle roar?
Hooker Aero Chambers
But that’s just my opinion…..
You have to make up your mind if you want quiet or noise. Don't really believe that you can have both. No free lunch.
I like the quiet exhaust and the real sound of my engine. Loud droney mufflers suck.
