Snake
Mopar Nut
OK looking for tipssssssssss,on how to R R the U joints, I am working on front and rear @ Home with no special tools,would a Clamp work.Thanks gang.
Do you have a good vise? That's really all you need. And some assorted size sockets to use as adapters/recievers
YEP I do but its a cheep 1 and in the basement with very little room,how is it done with a vice?
Basically, just like Memike and Cannucky do , only use the vise top squeeze them out using a pusher socket an a catcher socket. That's why you need a good size vise, you gotta crank on it hard sometimes. I always use my vise to re install them so I don't have to beat them with a hammer. However I do have an expensive ball joint press that I use to disassemble them smoothly .
Don, this will help you, and is the way I do mine.
I can R&R both ujoints in about 10 minutes once it's on the bench using this method, but I just use a 4x4 chunk under the yokes to support the driveline.
http://www.youtube.com/watch?v=rOEdul7nscY
Looks simple enough,do i do the same with the front 1 as well.Ihave done the rear ones on outher cars years ago with a BFH for sure,but for some reason i had a vib going on after.ale:
