Mgc340
Selling my personal R3 W8 engine.
Life changes and I’ve decided to go a different route on things with my car.
-R3 block P4532907
-Siemese block 4.145 bore
-Bryant crank 3.3ish stroke (I haven’t took it out)
-9.00 deck height
-W8 heads fresh from Brett Miller
-2.18 in, 1.63 ex valves
-Jesel rockers 1.65 (Intakes are new)
-Jesel keyway lifters
-Mopar (Ritter 420) as cast needs to be drilled and cut for deck height
-msd distributor
-Carrillo 6.0 rods
-Diamond pistons 14:1 compression
-drysump
- currently has a oval track cam with roller bearings
-Alternator, Mopar water pump, power steering pump and motor plate. Mechanical fuel pump.
-340 mains
This was originally a old nascar motor that has been updated over the years. My intentions were to freshen it and run it.
it needs new bearings and rings. The bearings actually look great in its current state.
this could be converted back to a wetsump motor as you can see by the rear main cap.
this motor is complete from intake to pan.
$8,800 firm. I don’t need to sell. Can ship in the lower 48 through Fastenal Hardware for around $250. Please pm me for more pics and information if you’re serious. Thanks
-R3 block P4532907
-9.00 deck height
-msd distributor
-Carrillo 6.0 rods
-drysump
-340 mains
