At our home track. Saskatchewan International Raceway. Rolled 3 times. Driver shaken up but is ok. The station wagon. It’s a turbo car. 138 mph. Thank god and IHRA for all the safety equipment. Kim
Yes I was. I seen it. They are pretty tight lipped as I think (and this is my thought) that IHRA may have an investigation into why he was allowed to run. Apparently the guy has been plagued with oil leaks.
That is exactly the reason I always ran a engine diaper on my car. When you throw a rod or engine blows a hole in the block or pan, the rear slicks get oiled down and this happensThis car ran 8.20s earlier in the day at 165 mph. He has been fighting oil leaks the last couple of races and they didn’t jet him run. Last time back it had a slight leak that the staff saw but they still him run. Track hasn’t released any info yet. It started smoking bad b4 it rolled. Speculation is that the oil leak got under the rear tires then that was all she wrote. As for being a fast Ford it isn’t. It is LS powered. Kim
I have to say the safety equipment did its job. When it was on fire I thought he may burn to death. It was a scary situation for sure. Kim
