Radiator dimensions
harvenator
A fish called Wanda
El Paso, TX
If any one out there actually has an original radiator for a 65 Barracuda with a 273 could you please measure the vertical outside dimension for me? I need from the bottom of the bottom tank to the top of the filler neck.
Thanks in advance.
Just measured mine as I'm lookin for a replacement radiator. The original is 22 1/2" tall to the top of the filler cap. The only aluminum radiators that I can locate are 1 1/4" taller or 23 3/4" tall including the filler neck. Mine is a '66 original 273 Cuda. Know the post is old now but trying to help. Does anyone know how much clearance is available below the hood on the 66 Cuda using a stock radiator? Thanks!
