radiator hoses
moparraceman
mansfield ohio
would any one happen to know part numbers for radiator hoses when putting a 340 in a 64 dart with alumin radiator like from auto zone ? or any parts store thanks
Whats the configuration of the rad inlet, and outlet to the water pump,??. I have aluminum Northern Radiators in my 67, and 69 B-Cudas, with a 273, and a 340. Top hose is on pass side, bottom hose is on driver side. I am using 69, and back cast iron water pumps, on both. Both hoses are Gates. The upper # is 20875. The lower # is 25527. These hoses were said to fit 64-67 Coronets, with 440 big block. Hope this helps.
Dave
