I know it's been discussed before but looking for first hand experience. Car has 11 to 1 416. Currently has aluminum 22wide large 2row. With no Trans ports. Temp hits 160 almost as soon as get backed out of garage and hit pavement.160stat. Yesterday was 84 here went for about 30 min ride temp rose steadily to about 195. Acted like the more I drove the warmer it got. Trans also climbed to almost 220 only hooked through a cheap aluminum tube cooler. Has homebuilt shroud and 18" flex fan. Looking to replace with 22 or 26 3 or 4row with duall electric fans, and Trans ports. Bottom of rad support has allready been cut. What are you guys using? Anyone using the champion mc374 w duall 12" fans?
