Batesy
I recently purchased a stock AM radio for my 75 Dart. Installed and it works fine except that when I accelerate the signal gets louder. Idle and especially reverse, the sound level drops. To be extra clear, when I am idle or reverse it's one sound level and then when I accelerate it gets louder and stays at the volume level no matter if I slow down or speed up. Just at idle and reverse does the sound drop a little.
While I am mentioning that, a second problem is that I have the Redirad system hooked up and it works fine too except that it has acceleration noise. Now, I have the power connected to a 20amp fuse which it shares with my tachometer. I am thinking that the tac is transferring the sound. I may need to move the power cable for the Redirad to somewhere else.
Perhaps someone has had a similar problem and can offer some advise. Thanks
