rally dash radio retainer
bmaudlin
Tucson, Az.
Rating - 0%
0   0   0
am looking for a retainer stud that holds a thumbwheel style radio into a Dart with a rally dash. Could also use the 2 larger style nuts that thread onto these retainers also. The first picture shows one installed in the dash in the upper corner. The hole with the slot in the lower right corner is where the additional stud needs to go.
also need a knob for a 2 speed wiper switch. The one pictured is for a 3 speed wiper motor and has a larger hole in the back. I need the one with the small shank size on the switch. Thanks, Ben.
I think that was called a keyhole stud. Same were used to support the dash speaker in many mopars.
If you dont find the correct ones, there is a substitute. It's a T bolt trimmed to fit with a push nut behind it to hold it in place. Fastenal may have those. If not Mr.Gs fasteners does. Good luck
